6 pin power adaptor external hard drive
i need a 6 pin power adaptor for unknown make of external hard drive
2 answers Last reply
More about power adaptor external hard drive
  1. There are two possible pinouts. Choosing the wrong one will seriously damage your drive or enclosure or both:
    http://ep.yimg.com/ca/I/laptopupgrade_2224_8521510
    http://ep.yimg.com/ca/I/laptopupgrade_2224_8506639
    If you need to determine which of the pinouts is the correct one, then you could use a multimeter to measure the resistance between each mini-DIN connector pin and the corresponding pins at the SATA or Molex power connector.
    http://pinouts.ru/Power/sata-power_pinout.shtml
    http://pinouts.ru/Power/BigPower_pinout.shtml
Hard Drives Power External Hard Drive Storage
