Need Help << my PowerColor HD 2600 XT >> problem >>
May 25, 2010 8:26:03 AM
Hey All,
i had bought this card from just 2 days ..
i was a GeForce 7300GS user ..
PowerColor 2600XT 512 DDR3
the problem is in the videos, any video i play on my pc it plays with very low quality ... these videos is a Blu-ray Movies or Videos ...
and my GF 7300GS was playing the same videos in a very high quality ..
i changed my Windows 4 times for now ... and changed the Version of Catalyst 6 times ... i really don't know what i must do ...
sooo plz HEEEEEEEEEELP .. :cry:
a c 189 U Graphics card
May 25, 2010 10:30:26 AM
From where did you install the driver for your card?
Inside CD which came with the card?
Did you remove previous driver (7300GS)?
May 25, 2010 10:37:01 AM
Yes, inside the CD that came with the card ...
about the Driver of 7300GS, yes i removed it and installed New Windows with the CD Driver it's version Catalyst 8.3
and thx 4 the help
May 25, 2010 11:00:23 AM
What player did you use to play?
Operating System?
You can try another player and see if that makes any changes...
a c 172 U Graphics card
May 25, 2010 3:07:32 PM
Get the latest drivers and update your codecs. This is one of the most annoying problems on ATI cards I have ever came across. VCL sometimes needs to be reinstalled when moving from older cards.
