Help with PC build; selecting power supply and graphics card
Last response: in Components
August 31, 2010 2:28:22 PM
I'm new to building a PC, but here is what I have selected for my first build. Let me know what you guys think, and I need an opinion on what power supply I should get and graphics card.
Case:
http://www.xoxide.com/apevia-xdreamer3-black.html
Motherboard:
Processor:
http://ark.intel.com/ProductCollection.aspx?series=4292... (I figure I would go with the X3440)
Power Supply:
Need opinion
Graphics Card:
Need opinion
Sound Card:
Transfer over from old PC
I am really new to this so any comments and/or suggestions would be appreciated.
Thanks -Con
a c 139 ) Power supply
a b U Graphics card
August 31, 2010 2:33:02 PM
Hello Lutticon;
You didn't mention what this system would be used for, or what your overall budget was.
Using this form helps people understand what you are trying to do so they can better help you. *How To Ask For New Build Advice*
m
l
August 31, 2010 2:39:24 PM
Sorry I also forgot to specify I would be using (2 x 4) 1333 Skull ram i believe it was (I will have to look it up). I use 64 bit windows 7 o/s. I will use this computer mostly for gaming, CAD software, videos/ music. Budget is not important, under a 1000 dollars though.
m
l
August 31, 2010 3:28:11 PM
Anyone have any recommendations for graphics card and power supply?? And how this setup looks and will behave.
m
l
