Hi,,
Is my router broken?(need to be replaced?)
I am already using this router for about 2 yrs. Now suddenly, I lost internet connection and windows says no internet access (using windows 7). now I restarted the router and modem but still no internet. I then thought the there may be a problem with the ISP, but then i connected the modem directly to my pc (stand alone, not through the router)and there was internet.
I have reset and re configure the router a dozen times already but still no luck. Does this mean my router is already broken?
I am having doubt because the wireless network is working properly ( i can access files through the wireless network) and other device can connect to the wireless network, but no internet connection.
What shall i do? I have exhausted all my options.. )
THX
THX
