I have a Samson Go-mic that is USB, it records sound but have no sound when I try to play it back. My sound card does not have a USB port so I am using an on board port.
The USB mic will ignore your X-Fi completely and is a separate device in Windows. Are you sure it's recording? How are you trying to play it back? Do other sounds play correctly?
Yes all other sounds play correctly, I am trying to narrate a video using video editing software( Magix movie edit pro 15) it actually gives me a wave form on my audio track but will not play.
