G
Guest
Guest
Hello,
I keep getting this balloon message popping up
"You just unplugged a device from the audio jack"
My sound keeps going and when I test the sound in "play back devices" it doesn't work, but then 5 minutes later it will work, but then it wont a few seconds later. The sound stops when playing games and listenng to itunes. Even the windows start up sounds didn't make a sound when I turned the PC on.
Cam someone please help me? This is driving me crazy and ruining my PC experience.
My PC:
Vista Home Premium 64Bit
Asrock x48 Turbotwins
E8500 3.16GHz Core 2 Duo
HD4870 Radion 1GB Graphics Card
4GB DDR3 Ram (using 2 Sticks out of three, so would be 6GB if i used all three).
Thanks
My PC:
Thanks
