A aaron_s Honorable May 17, 2012 75 0 10,630 Aug 30, 2012 #1 I'd like to know whether a seagate goflex upgrade cable USB3.0 will be compatible with any SATA drive.
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 30, 2012 #2 It will work with other drives too : ) Upvote 0 Downvote
A aaron_s Honorable May 17, 2012 75 0 10,630 Aug 30, 2012 #3 nikorr : It will work with other drives too : ) Thanks dude! BTW,I had some other questions too. Now these portable hdds that you get in the market, do they all have a 7200RPM disk in them or like say 5400 etc. Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 30, 2012 #4 Well, cheaper ones are slower, mostly 5400. But it depends on the model : )) Upvote 0 Downvote
nikorr Champion Oct 22, 2009 23,335 0 54,960 Aug 30, 2012 #5 Than u have small factor drives, slower @ 2.5" and slow as 5200RPM Mostly used in laptops... http://www.newegg.com/Product/Product.aspx?Item=N82E16822211067 Upvote 0 Downvote
A aaron_s Honorable May 17, 2012 75 0 10,630 Aug 30, 2012 #6 nikorr : Than u have small factor drives, slower @ 2.5" and slow as 5200RPM Mostly used in laptops... http://www.newegg.com/Product/Product.aspx?Item=N82E16822211067 so you mean to say that 3.5s are faster than 2.5s? but 7200RPM is the way to go! Upvote 0 Downvote
