Closed Solved
POWER SUPPLY for GTX 470
Hello folks,
Would my PSU ( thermaltake 850w) handle this graphic card? NVIDIA GTX 470
These are my specs:
- Intel core i7 920 @ 2.6ghz
- Patriot DDR3 1600Mhz
- thermaltake 850w
- Nvidia GTX 280
- 2 SATA HDD's
- 2 optical drives
Thanks!
5 answers Last reply Best Answer
More about power supply
  1. nvidia recommends 38a on the 12v for the GTX470 (probably a bit over kill) and your PSU has around 69a so you will be OK.
  2. Best answer
    Depending on the model of your Thermaltake, you should be able for doing even SLI using two GTX470. Don't worry.
    Anyway, take a look at the PSU Review Database (by RealHardTechX) for reading qualified reviews about your PSU:
    http://www.realhardtechx.com/index_archivos/Page680.htm
  3. thanks guys!
  4. Best answer selected by xxarkzeroxx.
  5. This topic has been closed by Mousemonkey
Power Supplies Gtx Thermaltake Nvidia Components Product
