Hi guys! I am building a gaming computer for the first time. If all goes well I will build my wife one as well. We mostly play WoW. I have put together a list of parts I need you guys to tell me if they will work good with each other. PLEASE tell me if I'm missing something or if I need to change something. Be brutally honest!
CASE- RAIDMAX SMILODON ATX-612WB Black 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case
(http://www.newegg.com/Product/Product.aspx?Item=N82E16811156063)
CPU- AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
(http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727)
MOTHER BOARD- ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
(http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366)
VIDEO CARD- EVGA 768-P3-1362-AR GeForce GTX 460 (Fermi) Superclocked 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814130564)
POWER SUPPLY- CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
(http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005)
MEMORY- A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-2G
(http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409)
HARD DRIVE- Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
(http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218)
Optical Drive- ASUS 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24x DVD Writer LightScribe Support
(http://www.newegg.com/Product/Product.aspx?Item=N82E16827135209R)
Flash media writer- Kingston FCR-HS219/1 19-in-1 USB 2.0 Card Reader
(http://www.newegg.com/Product/Product.aspx?Item=N82E16820134753)
OS- Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
(http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754&cm_re=operating_system-_-32-116-754-_-Product)
Ok thats it thanks guys. What about the Optical drive???
