I recently finished building a new gaming rig for my son. Everything seems to be running smoothly except for power issues I'm having since the beginning of the build.
Occasionally when I disconnect, move the computer to another area and try to reconnect, the system would not power on. I can see that the mobo power led is on, but the computer would not power on. I have to unplug and re-plug the 24 pin connector to the mobo and then the system would power on. We also had few incidents when the computer would power off, and then I disconnected and reconnected the 24 pin connector in powered on.
The system ran fine for 3 days and yesterday I took it apart, reseated the motherboard, reapplied the thermal paste and the computer runs cool on idle 30c, while gaming 45c-50c and under stress test using IBT and Prime95 would go up to 63c - 65c.
The issue is intermittent and I'm trying to figure out if I should RMA the power supply or the mobo. Unfortunately I don't have another 'beefy' power supply to test with nor do I have a multimeter to test the PSU.
- Antec Mid-Tower Gaming Case Nine Hundred Two V3
- ASUS P8P67 PRO LGA 1155 SATA 6Gbps
- Intel Core i5-2500K
- G.SKILL Ripjaws X Series 8GB (2 x 4GB)
- Corsair CMPSU-850HX 850-Watt HX Professional Series 80 Plus Certified Power Supply
- Palit Geforce GTX 560 Ti 2048 MB 256-bit GDDR5 PCI Express 2.0 x 16
- Zalman CNPS9700LED Ultra Quiet Cpu Cooler
- Intel X25M 80 GB Solid State Drive
- Western Digital 640 GB Caviar Black SATA 7200
