Hi all, I just bought and setup an antec 1200 case, a 850W Antec PSU, and an arctic freezer 7 pro CPU cooler
It's just.. everything works just fine.. (apart from I broke my gtx260 in the process luckily i had a backup one... so much for SLI!
ANYWAY... My idle temp of my (not overclocked) Q8200 cpu is 55-60 degrees on idle, and around 80 on load :s
All fans are not covered up by wires or anything and it's actually worse than before I made this awesome upgrade! WHAT DO I DO Please help me! Also now the old cpu fan makes no difference and the new ones DEFINITELY plugged in correctly. What would YOU do?!!
(antec 1200 with no dust filters and all fans on highest makes no difference)
