Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > HP pavillion a1355a wont power up
Forum CPU & Components : CPUs HP pavillion a1355a wont power up
I have a HP pavilion a1355a that just won't boot up. The LED light is green initially, but as soon as I press the power button it goes off. After pushing the power button, the CPU and the system fan turns on. The hard disk and the DVD drive are receiving power and are on, but the monitor says no signal. Had a technician check the machine, who said that the MOBO is gone. So ordered a new MOBO, HP RC410-M. Replaced the MOBO and yet the same situation. Not to mention I got poorer by $100 (by getting the new MOBO). Any help in getting this machine to boot up would be greatly appreciated. By the way, could the issue be with CPU? I do not have another machine to eliminate what the problem is.
Reply to sgangar
CPUs generally just don't die out. Are you sure everything is connected? Including the four or eight pin CPU connection?
Reply to Lmeow
Yes, I have checked the connections. The 24-pin connector that provides power to the motherboard as well as the 4-pin connector that provides power to the CPU. There is no beep or bios display. The CPU fan and the system fan turns on. The fan on the PCIE X16 graphics card is also on. But the system shows no POST. I even took the motherboard and PSU out of the cabinet and ran it with bare minimums, i.e. cpu with heatsink, mouse and keyboard and by short circuiting the power pin with a screw driver and yet no POST.
Reply to sgangar
There are 2180 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 5 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
