Hello,
i have a TOSHIBA Satellite Pro A200-EZ2204X NoteBook Intel Core 2 Duo T7250(2.00GHz) 15.4" Wide XGA 1GB Memory DDR2 667 120GB HDD 5400rpm DVD Super Multi Intel GMA X3100:
I just recently ordered this ram and installed.
G.SKILL 4GB (2 x 2GB) 200-Pin DDR2 SO-DIMM DDR2 667 (PC2 5300) Dual Channel Kit Laptop Memory Model F2-5300CL5D-4GBSA
It seems the laptop is now going slower. How do i check to make sure its running at the speed it should be? The computer is registering at 3GB which i knew would be the case cause its win xp pro 32bit. Help!
