Bootcat.cache solutions not working, please help
loopylulu
For the last month I have had to do the following:
I am dual booting windows 7 and XP but XP seems to have it's own problems and I have grown to really liking windows 7.
I have to load the boot screen, boot windows 7 files from USB key, run the command prompt and replace the bootcat.cache file found in windows\system32\codeintegrity\ with one I have saved in another folder on my computer. Then I have to restart and load the boot screen and change to booting from my harddrive first in stead of the usb key.
Needless to say this is incredibly frustrating.
The solutions for this problem have not helped me so far, most places on the internet say to delete the bootcat.cache file and restart but it does not work.
I transferred the bootcat.cache file from my wifes laptop and it seems to work.
The only difference is that it takes a little longer to load up and once I am in windows it seems a little slower in certain areas but games, which are demanding, seem to run fine.
If I do not follow the above procedure and boot as normal I will get the BSOD every time.
Please help me here.
I have scanned multiple times but to no avail and I simply do not want to start fresh.
Any thoughts?
thank you
Any thoughts?
thank you
answer
Last reply
More about bootcat cache solutions working help
Windows 7
Cache
Windows XP
Related Resources
- Windows Booting Problems [Please help..]
- Replaced Motherboard, now Windows 7 won't boot up.
- Boot Windows XP via USB key
- Dual Boot gone wrong
- Boot Problems. Corrupt file
- Help! I've reformatted my 311 cache SSD and cant get up!
- Did I delete my HDD cache?
- Vista 64 Bit + 2 x 500 gb 32mb Cache...
- Gm.dls cache file
- Windows 7 install with SSD Cache
- Fixed cache size
- Booting from USB key
- Can't boot from usb
- Boot from a USB in Windows 8
- DNS Cache
- After POST, trying to boot into SSD, blinking cursor. Asking for cache data failed
- Windows 98 Startup/Boot problems
- L1 Cache - Help!!
- Setting IE Temp Files cache via GPO
