G
Guest
Guest
Hi all,
Firstly, can I just point out I am quite new to RAID so apologies if this sounds silly.
I recently acquired a ProLiant ML110 G7 but read that the onboard B110i controller wasn't supported by ESXi.
So I decided to add a HP Smart Array P410/256MB Controller. I wasn't sure if there was specific disks required for compatibility, but I tried to get something similar to what came with the server, albeit with greater storage, so I purchased 4 x 2Tb Seagate disks, model ST2000DM001.
Now, when booting the server using the HP SmartStart and going to the ACU to configure the array, I receive an error saying "No supported controllers". The controller is visible in the BIOS and I can see it attempt to initialise via the ORCA messages.
I don't know if it's a compatibility issue or something else.
Any thoughts are appreciated.
Thanks
Thanks
