This question is about specifications and relative performance/cost
Origionally I wanted to upgrade and keep my
Q6600
Nvidia 260 GTX
750W PSU (Thermotake)
however..... Q6600s can be seriously outclassed by a cheap i5-750, so I intend to purchase one of those.
So bascially, now I have a 260 GTX and a 750 PSU, and the appropiate skills to assemble, install and finally overclock my machine.
My current intention is to purchase:
MAINBOARD
-Asus P7P55D-E P55, 4DDR3, FSB2133(OC), RAID, GBLAN, PCIEx16, SATA3, USB3, ATX
- (Note the Dual Channel Memory and dual PCI-E - which in a dual setup will allow x8 speed, which does not bottleneck my GPUs in that current configuration, but only just)
CPU
- i5-750
- and buy a Zalman Cooling Device (the best one according to the benchmarks) so hopefully I can achieve a stable overclock around the 4.0 GHz mark, with a suitable multiplier
MEMORY
- G.Skill 4GB (2x2GB) Kit, PC-17066 (2133Mhz), Trident, 9-9-9-2N, Dual Channel Kit
(Note the high clockrate and the relativly low latency)
HDD
- keep my own
GPU
- another 260 GTX and SLI then Overclock them
PSU
- intending to keep my 750,
Ok from this, the questions I have as as follows....
What sort of stable overclock would I possibly expect with a i5-750 hooked up with a Zalman CNPS10X?
Will my memory provide superior performance than similar in price (Corsair), with higher latency and lower clockrate, because I have heard some rumours about my cpu bottlenecking my RAM's clockrate anyhow?
Will my 750W psu provide enough power for such a configuration, and if not, would it be possible for me to use my old 600W to supply the GPU auxillary leeds? (which would negate the problem)
And most importantly...... Will I be able to buy a nvidia 3d setup and run empire total war with darthmod and all the toppings in 3d?
Cheers,
Q6600
Nvidia 260 GTX
MAINBOARD
CPU
- i5-750
MEMORY
HDD
- keep my own
GPU
PSU
Cheers,
