Can anyone suggest the best memory choice for the following......
Deciding between the two MOBO's.....
ASUS P8P67 WS REVOLUTION LGA 1155 Intel P67 / NVIDIA NF200 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #8P67WSREVOLUTIONREV
Item #:N82E16813131714
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131714
-VS
GIGABYTE GA-P67A-UD7-B3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:GA-P67A-UD7-B3
Item #:N82E16813128480
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128480
For memory, I have always had good luck with Corsair. I have heard, however, good things about GSkill.
I hear 1600 speed is the sweet spot for my Core i7-2600k choice.
What I have picked is......
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C8
Model #:CMZ8GX3M2A1600C8
Item #:N82E16820233147
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233147&Tpk=CMZ8GX3M2A1600C8
8-8-8-24 / Cas 8 / 1.5v
As above, I like Corsair. My concern is the size of heat sinks and a 3rd party CPU cooler.
-VS-
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL8D-8GBXM
Model #:F3-12800CL8D-8GBXM
Item #:N82E16820231445
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
Love the blue color. Specs look same as Corsair.
-VS-
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBXL
Model #:F3-14900CL9D-8GBXL
Item #:N82E16820231455
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231455
9-10-9-28 / Cas 9 / 1.5v
Red color and looks like slight different settings C/W above.
So......
1. These good choices for either of the above MOBO's?
2. Which would be the best choice?
2. Would you recommend anything else?
-VS
-VS-
-VS-
So......
