High SMART Values - Seagate Says It's Normal
Last response: in Storage
I had purchased a HDD from seagate and it had read failures in the millions within a week of use. I called in to get it RMA'd, the tech told me it was normal with seagate drive and to ignore the SMART numbers. I insisted on a replacement and I just got it today. I installed the HDD and currently have 48472 read errors, 550 write errors, 15938623635456 head flying hours??
The read errors is steady but If I begin a copy from one of my other TB drives the write errors increase at a rate of about 1 per 2 seconds. The "head flying hours" increases at ridiculous speeds.
So IS this actually normal? Should I just ignore the smart as seagate suggested. This seems pretty ridiculous.
sounds like a "Certified Like New Replacement". It broke for someone else, they thought they fixed it and sent it to you. (common practice unfortunately.)
What are you using to gather the SMART info? The data could be totally bogus.
@xGhost4000x, the raw values of the Read Error Rate attribute are sector counts, not error counts. Ditto for the Seek Error Rate.
See http://www.users.on.net/~fzabkar/HDD/Seagate_SER_RRER_H...
In fact, I recently discovered that SandForce SF-2000 SSDs have very similar error rate attributes:
http://hddguardian.googlecode.com/svn/docs/Kingston%20S...
As for the Head Flying Hours, the raw value is best viewed in hexadecimal mode:
15938623635456 = 0xe7f00000000
I believe that the actual number of flying hours is stored in the lower 32-bits (= 4 bytes). In your case this value is zero (= 0x00000000).
Ask the community
