hello everyone. i am using a evga p55 sli mother board and am using onboard sound, realtek. while listening to music on rhapsody i am hearing static and it's choppy too. I don't seem to have as much static on slacker radio and none at all while listening to mp files( i can't tell if it does it during games). this all started after I reformatted my computer(i don't remember it doing this before). I also added missing screws to my motherboard that i had missed when installing it but don't recall if it did this after or not. I added the screws before i reformatted so i guess it's either of the two.
the static happens randomly and is in small burst. happens alot more while listening to rhapsody then anything else. I checked my headset (creative fatality,non usb ones) it was okay on my other computer. i tried reinstalling the drivers, but that didn;t help(used driver sweeper). so why would this be happenings? could it be the screws or do I just need to upgrade to a sound card? i heard a case not being grounded right could cause static. do you think this happened when i installed those extra screws? I would take them out but i don't recall what ones i installed =(
i really don't know what sound cards to get for my use. all i do is listen to music and game and i am using a stereo headset(creative fatality ones). what would you all think would be a good one to get if i do upgrade to a sound card? I really don't want to spend more than 100 dollars if i can help it. these are the following sound cards I thought about getting but I don't know if they're overkill for me or not. here are the three i might get if they would be good for me.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102019
my setup is the following
evga p55 sli mother board (i have one pci 1x slot and one pci slot open)
i5 750 cpu oc 4ghz
corsair 1600 88824 memory
2x msi 460 cyclones 1gb
vista 64
i5 750 cpu oc 4ghz
vista 64
