Psu problem
Hello guys,i have just bought sapphire 5770 1gb and i want to know if coolermaster eXtreme Power Plus 460w psu good for it and below are my pc spec:
intel core 2 duo e4500 2.21ghz 3gb ram
5 answers Last reply
More about problem
  1. Yes. A CM 460 produces a total of 26 amps at 12 volts. Ignore the "2 rails at 18 amps max" on the PSU label. Look at the total power: 312 watts - or 26 amps.
    The CPU and GPU each need about 8 - 9 amps.
    More troubling is that CM PSU's are excessively mediocre PSU's. A higher quality PSU would be better.
  2. anonymous1, nice link to the PSU calculator!
  3. thanx,so which psu do u suggest me to go for
  4. i cant afford more than Rs 2500 (45$)......so any advice please
  5. Take a look at this PSU and cost after rebate: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341010
    Meets your criteria
Graphics Cards Cooler Master Sapphire Graphics Product
