wide angle (28mm), AA batteries camera?
Archived from groups: rec.photo.digital (More info?)
Is there a compact model that has wide angle (28mm equiv) and uses AA
batteries?
For some reason, canon makes cameras with 28mm wide angle (S60, S70, Pro1)
and they also make cameras that use AA batteries (A series), but they don't
have one camera with both features.
Even though there are hundreds of digital cameras to choose from, it is hard
to find what I want. I wish digital cameras can be customized like ordering
a PC.
5 answers Last reply
More about wide angle 28mm batteries camera
  1. Archived from groups: rec.photo.digital (More info?)
    In article <cShxd.313$L7.254@trnddc05>, peter <nospam@nospam.com> writes
    >batteries?
    >a PC.
    If you are prepared to compromise slightly on the 28mm requirement you
    could purchase a used Kodak DC-280 which has a 30-60mm 2x zoom and runs
    on 4x AA. These cameras are 2Megapix but got good reviews for image
    quality and are now relatively inexpensive.
    David Wright
  2. Archived from groups: rec.photo.digital (More info?)
    > batteries?
    > a PC.
    Perhaps a Minlota Diamge 7 would be a contender?
    28-200mm (35mm equivalent) lens and uses 4 AA batteries.
    It also has a ton of features that make it almost as versatile as a true
    dslr.
    Second-hand off eBay would be the way to go.
  3. Archived from groups: rec.photo.digital (More info?)
    >> batteries?
    Coolpix 5000, with the accessory AA battery holder -- The 6 AA cells will
    power the thing all day, it seems. Add the accessory lens, and the field of
    veiw becomes equiv to 18mm or so.
    Bob
    Delete the inverse SPAM to reply
Photo Cameras
