While installing the stock cooler/heatsink for my AM3-based processor (Phenom II 1055T), I had some problems locking the cooler in place. If I insert the metal bracket on one side into the plastic clip, the other bracket won't go down far enough to lock into the motherboard's rectangular plastic clip.
While attempting to fix that, I locked the side with the black lever into the plastic clip, then pushed the other side down into that plastic clip by force. It finally worked, but I heard a loud snapping sound. Now it's no longer possible to turn the black lever and remove the heatsink.
My questions:
- Does this sound like something had seriously gone wrong?
- How can I remove the cooler?
- Is there any chance my CPU was damaged?
- I had to previously remove the cooler after the thermal compound dried. After all of the above happened, the cooler still seems a bit loose. Does this mean I need to replace the compound?
Thanks in advance.
My questions:
Thanks in advance.
