OK I have this old-ass Rosewill case...R5604-bk...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147037
And I've been looking for a replacement side panel with a window.
Anyone know where one can be had???
If need be I can do some cutting on my panel, as I have the use of a metal fab shop
If i do cut the thing up, what type of material should I use for the window??
I was thinking acrylic , glass , or plexi-glass?
