hi,
My question is: if you have a system that uses like +-500 watt and you buy an psu of 700W, is your psu going to use less then 700w for your system or is it always going to use 700w
i want to put this in my pc:
Asus AM3 M4A89GTD PRO USB3 HDMI DVI VGA DDR3
AMD AM3 Phenom II X6 1055T 2.8GHz BOX
ASUS ATI 5850 Direct CU 1GB DDR5 voltage tweak ed.
Kingston DDR3 4GB 1333MHz (2x2GB) CL9
I know that antec tp-550 will do the job but i dont know how much noise it makes. If a psu of 700 watts does use less then 700w then im going to buy the cm 700w silent pro because i know that will quiet.
I'm a bit new with psu's.
I hope you guys can help me.
