New WD VR 1TB drive is making a lot of noise
https://www.youtube.com/watch?v=gU-pKdbtUPA&t=28s
Is that normal? Sorry for vid quality but the sound is the most important part, not the video itself.... after a bit I run the WD hard drive tool and it makes a very weird noise....I just got this HDD from newegg 2 days ago.
thanks
2 answers Last reply
More about drive making noise
  1. I use the 2.5 inch version and yes they are loud.
  2. Hi Kazy, & welcome to Tom's Hardware!
    Can't really tell from the UTube what is HDD noise. The title indicated it is a Veloci-Raptor 10,000 RPM drive.
    The clicking noise I heard at the start of the clip is not a normal finding, usually means trouble.
    Here is a website that permits you to listen to all the abnormal sounds HDD make, for comparison, and what they mean:
    http://datacent.com/hard_drive_sounds.php
    After comparing "sounds", I'd either just call WD directly, Tele # 800-275-4932 , and talk to them about it (they will record the drive Model and SN), or just send it back for a warranty replacement from NewEgg.
Hard Drives Western Digital Storage
