Final FINAL build-- help!
Last response: in Systems
Hey guys, a few months ago i had almost purchased my first build but it took longer than expected to get the money together :(  since then, the availability and price of some components have changed. Im living in Ireland and it can be quite difficult to locate parts here . The following is hopefully my final build. this is my first build so i appreciate all comments and advice. Please tell me if something isnt compatable. THanks....
PS. i dont require a case or PSU- thanks
CPU: Phenom II x4 965 (with Coolermaster Hyper 212)
GPU: Saphire HD 5870
MoBo: Gigabyte GA-790FXTA-UD5
RAM: Corsair XMS3 - Memory - 6 GB : 3 x 2 GB - DIMM
WD Caviar Green WD10EARS - Hard drive - 1 TB -
CD Drive : something cheap havent looked yet!
Windows 7
Monitor: LG W2343T-PF - LCD display - TFT - 23"
More about : final final build
Mark Heath said:
Apart from what wasabi said, on the whole it looks pretty good. Are you overclocking?
That hd isn't really bad, it's just not the best.
eh not really planning on overclocking ,no
Ask the community
