Tom's Hardware > Forum > General Networking > Network General Discussions > Do you prefer wire or wireless networking?
Forum General Networking : Network General Discussions - Do you prefer wire or wireless networking?
Greetings:
Let assume that you need to purchase a router (similar in price) right now for your home networking. Which one will you buy, wire or wireless (802-11g)? What is the particular (speed, easy setup, reliable etc) reason for you to get either one?
Thank you for your feedback
Sponsored Links
Again, A little late on this one, but it all depends on you. Wireless is a little more expensive, but more versatile, especially if you are going to be moving computers around . If they stay there, use the old tried-and-true cabling. Performance. I don't think you would be doing anything intensive enough to see a difference between the two.
For network intensive solutions, cabling always works better, hands down.
Reply to Jim
- 0 +
well, if you're talking B, in general there's usually a noticeable difference vs. 100BaseT
Especially when you're on the fringes of range.
But yes, with the wire you wouldn't be ABLE to b on the fringes of range.
So, for laptops, go wireless. Desktops, physical.
Get yourself a combo router - AP and router.
<pre> \|/
jlanka (. .)
___________oOOo_(_(_)_)_oOOo___________
</pre><p>
Reply to jlanka
- 0 +
Thank you both for your input.
I would wait and will get a Belkin PreN Super G router when it is available on the market. I will never buy Netgear again. I am so disppointed in their tech support. I have to pay $30 to find out that they just guide you through the Wizard setup for their troubleshooting. It's pretty weak. Let's see if Belkin is better on this. At least they have a life time tech support though.
Reply to jgfrank
I've had nothing but great results with my Buffalo 54g multi access router. Their tech support is 2nd to none.
A7n8x dlx 1004 Uber Agressive settings
2500Barton (Bastards locked it) Radeon 9200
WD 60g @7200w 8mg Cache Crucial 2700 2x 256
AMD ME??? Yeah they did me alright.
Reply to stupid_tech_geek
- 0 +
ive had bad luck with my netgear router. a lot of people out there have the same issues ive had.
wpdclan.com counter-strike game server - 66.150.155.52:27015
now featuring valve security module!
Reply to jihiggs
- 0 +
I'd get one that does both and use cables for hosts that need speed and .11b for wireless, since .11b has double range and most wireless clients only surf the web here at my place. YMMV.
I want my epitaph to be: "Moved to /dev/null"
Reply to Dev
There are 503 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
