Help! New System won't boot.
Ok, I just built a new computer. I went to boot it up and all the fans spin for about 1 second and then die. The only way I can reset this is by flipping the switch again on the psu. I already tried pulling the mobo and components out and booting from a table. No luck.
Hardware.
Raidmax PSU 700watt
ATI Raedon 5870
Amd Phenom II x4 965 125 watt
MSI 870-G54A mobo
Adata DDR3 1333G Ram
3 answers Last reply
More about help system boot
  1. Read the sticky about boot problems at the top of the page.
  2. stickys didn't help
  3. Included in that sticky is a link on how to properly format a build issue thread. Go fill that out. We currently have insufficient info to help you.
    You should also probably tell us exactly which steps in the sticky you followed and the result.
New Build Boot Systems
