Help knock off $200 of total pice
My friend wants to get a new PC and I told him I would build it for him so it would be cheaper. His limit is $900 and the parts I picked out are just about $1,100. He wants it to be a gaming PC so he can play games like Dragon Age.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=19669548
4 answers Last reply
More about help knock total pice
  1. Combos are your best friend in this case, drop $35 by switching to a 955 and comboing with the motherboard
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.436069
    Drop another $20 by comboing the HDD and PSU
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.431396
    Case and OS saves another $10
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.437504.11-119-068
    That knocks of $65 without even needing to change any parts significantly. The monitor is taking up a large chunk of the budget, so it might be good to downgrade that unless he specifically requested that one as it is consuming almost a quarter of the budget and if you can get one thats closer to $180 you will be much closer to the budget.
  2. thanks, i forgot about combos. He kinda wants a good monitor because his current one is crap. But ill see if he wants to for out a little extra.
  3. Just make sure you get the C3 version of the 955BE. If you're only going to use a single 5770 then you don't really need such a beefy PSU. You would really only need a good 450W PSU for this build. This Antec model would be more than enough
    Antec BP550 Plus 550W $59.99
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
    Be sure to also look through the weekly promotions for more possible savings
    http://promotions.newegg.com/NEemail/July-0-2010/WeeklySale/index-landing.html?nm_mc=EMC-IGNEFL071310&cm_mmc=EMC-IGNEFL071310-_-EMC-071310-Index-_-E0-_-ITmore#IT
    http://promotions.newegg.com/NEemail/July-0-2010/ITSale/index-landing.html?nm_mc=EMC-IGNEFL070910&cm_mmc=EMC-IGNEFL070910-_-EMC-070910-Index-_-E0-_-ODDall#ODD
  4. ^Note that the Western Digital Caviar Black WD7501AALS 750GB is $59.99 with the promo code and that would save you $25 over the Seagate. Also note the Thermaltake V3 that's 29.99 after promo codes and rebates
Homebuilt Build Systems Product
