Best sound cards for recording sounds
Hello,
looking for a mid priced sound (PCI or External) card that will allow me to record sounds from Audials One, anyone with experience and have tested feed back, I would like to hear from you. Thank You, Jake West
1 answer Last reply
More about best sound cards recording sounds
  1. i'm not sure why you would need anything special. this is just a 'free' media search engine / downloader, correct? once you've got the file, you've got it. were you looking to edit the material? what is your currrent onboard soundcard? if you're trying to work with media - remix, compile, etc - you'll likely just need a bit of software and there's an enormous amount out there from freeware to mid level pro audio to fully integrated software / hardware suites.
Sound Cards PCI Components Product
