Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Asus Xonar DX NO SURROUND SOUND!?
Forum CPU & Components : Sound Cards Asus Xonar DX NO SURROUND SOUND!?
Hey guys,
I've encountered a problem that I just can't understand, I might be doing something really stupid, but I don't think thats the case.
Anyway, I recently bought and installed an asus xonar DX, and all is well, apart from one thing that is concerning me. :cry:
I installed the latest audio drivers from asus, and sound is all well, I can choose from 2, 4, 6 and 8 channels, the asus dx interface says:
2 is the best for mp3 tracks and wma, cd, music.
6 is the best for dolby digital or DTS
and finally...
8 is the best for games with 3d sound.
I can play stereo tracks fine and pro logic II works fine with music etc.
But when I actually want to select 6 channel audio, and play a dolby digital or DTS track, no audio comes from any of the speakers at all, and I am right in saying that you do need a 6 channel audio track selected to benefit from the dolby digital or DTS split sounds sent to individual speakers right?
Now interestingly, when I select the 2 channel track to play a dolby digital or DTS track, audio comes from all speakers, BUT its only a stereo track being fed to all speakers, as there are no seperate sounds coming from specified speakers, e.g foot steps in the distance or something.
This is a bit annoying, as I want to enjoy the proper surround sound from my speakers, and I don't want to enable pro logic II for DTS or dolby digital audio, it defeats the object of buying a decent sound card.
Any ideas on what I am doing wrong or suggestions to solve this problem?
Thanks.
------------------------------ CPU: Q6600
Mobo: D975XBX2
GPU: XFX 8800GTX XT 768MB
Memory: (2x2GB) Corsair TwinX XMS2 DDR2 CAS 5-5-5-18, DHX
Reply to carlos_will
Not familiar with sound card, but how about rolling back drivers to a previous version/
Reply to mister g
- 0 +
The Xonar DX doesn't have support for digital surround from what I know. It supports 5.1 AC3 conversion. Check with the audio subforum.
Reply to mosox
The X-540's can not nativly decode a Dolby Digital track. That means if you connect using a digital connection and send a 5.1 Dolby signal, the speakers can not understand the audio stream, and outputs either nothing or white noise.
The X-540's can handle standard 5.1 analog audio streams without any issue, so just hook up via analog. Theres no reason to even worry about Dolby Digital/DTS technology in the PC realm anyways, barring a hookup to a Home Theatre setup...
------------------------------ http://valid.canardpc.com/cache/banner/1647132.png
Reply to gamerk316
There are 2008 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 8 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
