Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > Ultra low power motherboard
Forum CPU & Components : CPUs Ultra low power motherboard
Hello,
I am looking for a motherboard that uses less power than the Intel desktop board D510MO. My watt meter tells me the board, SSD and power supply use 32 watts when surfing the internet. My HP TM2 laptop uses 23 watts in similar use. The laptop performance is equal to my desktop. Where do I buy components that use less power like my laptop?
Reply to Anonymous
A huh? how do you get the board power usage? 32W is low for a D510 board as you're considering in the CPU also.
The fact is, 32W is low enough, as laptop parts are different compared to desktop parts as it is optimized towards efficiency rather than performance. Why do you need it lower?
Message edited by Timop on 09-14-2010 at 12:59:41 AM
Reply to Timop
And I thought getting 39-45(I5 750 under-volted + 4350 video on a m-itx board) watts idle out of my media center was good(54-59 with a 5770 video card)....Beats my desktops 144 watts idle.
You may be able to shave a small amount of power savings with a low wattage(250-300, lower if you can find a good one) high efficiency power supply.
You may also save some power by disabling any onboard devices that you do not need on the board. Undervolting may be an option if the board supports it. Make sure all power save options(Speedstep,C1E ect) are on in the bios and windows(balanced or power save).
Message edited by nukemaster on 09-14-2010 at 02:50:04 PM
------------------------------ http://i33.tinypic.com/sw3a5y.png
http://tinyurl.com/yfmxdc9 - Part Guide? http://tinyurl.com/5zk6me - VGA power?
http://tinyurl.com/5v55wk - C2 Mem performance? http://tinyurl.com/6pmbke - SLI/Xfire?
http://tinyurl.com/yjldsrw - No Boot?
Reply to nukemaster
There are 2016 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 8 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
