Hello community
First of all, I am posting this here because I am not entirely sure what the issue actually is but it's plausible the mobo is the culprit here based on what I'm going to share in a moment.
A few weeks ago I made a post about an issue where, when playing graphically-intensive games, my new rig would completely freeze. Sound would continue to play (such as music from the game) but graphically everything would be frozen and I would be forced to hard reset the system. At the time, this was happening with great frequency - say within five minutes of playing any game (and I did try with several different games with similar results across the board). An astute forum-goer here pointed out a few issues with my RAM:
- I was using RAM that was "advertised" as 1600 but really could only run at 1333
- I was using three sticks of RAM at 4GB a stick yet my motherboard was dual channel (A1, A2, B1 and B2 DIMM slots)
- I had the three sticks of RAM in slots A2, B1 and B2
I went into the bios and turned the frequency on the RAM down to 1333, removed the B2 stick of RAM altogether and moved the B1 stick of RAM into the A1 DIMM slot. After doing all of these, my system became quite a bit more stable and the system freezes were drastically reduced in frequency (say once or twice a day during days where I would game for several hours). However, this does imply that the problem is still there, albeit with less frequency. As a result, I'm reaching out to the community here to see if anyone has some insight on why this would occur. I provide all of the above as a history on the issue in case it helps.
Here are my spec:
- Asus p8p67 LE
- i5 2500K 3.3 GHz/core CPU
- Diamond HD Radeon 6970 2GB GDDR5
- Intel x25 40GB SSD (for boot and system software)
- Western Digital Black Caviar 1TB 6GB/s HDD (for everything else)
- 8 GB Kingston DDR3 1600 MHz RAM
- Thermaltake Black Widow 850W PSU
- Windows 7 Professional 64bit
Here's a bit more information:
- When I was installing the motherboard, I thought I had it seated perfectly but when I turned the system on for the first time it came on for a second, there was a strong burning smell and the system immediately turned off. I disassembled everything and found that, fortunately, only a few of the contacts around the motherboard holes towards its corner were burnt off (I don't claim to be a tech guru so let me say it a different way: there was no damage visible anywhere on the board except around two of the holes where screws go through wherein a few of the little "bumps" around the perimeter of these circles were burnt off). I reseated the board, hooked everything back up, turned everything on and it all worked great (aside from the system freezes).
- The system ONLY freezes when gaming. I have left the system running in Windows overnight and for days at a time with no freezes.
- I strongly doubt it is due to any kind of overheating. I have checked temps on everything and nothing is running abnormally hot.
- The time at which the system freezes can sometimes happen within the first few minutes after entering a game or I could play for hours upon hours and it will finally happen.
- The Windows event that gets thrown when the system freezes is of ID 41 and of type "Kernel-Power". I've done some googling on this and it seems that many different things can cause this and that this is just a generic event when the system fails altogether.
If there is anything else I can think of that might help, I'll come back and post it promptly. For now, that's all I've got. Anyone have any ideas? Thank you so much for your time in advance!
Here are my spec:
- Asus p8p67 LE
