Solved
Quadro FX 1800 Quiet Cooling
June 6, 2010 10:11:52 PM
Greetings All,
I'm building a new workstation and I'm dying to finally have a quiet machine. I have options for water cooling or quiet fans for all components EXCEPT my graphics card. I want to use a Quadro FX 1800 but can't find a quiet cooling option for this specific card. It uses the same core as the GeForce 9600 GT but apparently
Quote:
...This combination of characteristics makes the Quadro FX 1800 an original product that has no direct counterpart among gaming graphics cards. That’s why, like the other Quadro series models, it has a specially designed PCB whose face side is completely covered by the cooler.
Its really irritating to think that my quiet PC may be compromised because I can't find a method of quiet cooling for just one of the components. Also, I don't have time for a DIY milled heat sink. Can anyone please help!!!
June 6, 2010 10:30:15 PM
I'd love to hear about a block that would work with the FX 1800.
m
l
June 6, 2010 10:30:26 PM
Can't find many they really dont seem to output that much heat.
m
l
Best solution
June 6, 2010 10:31:38 PM
June 6, 2010 11:09:22 PM
Its a universal water block which is great. Thank you. I emailed thermaltake to double check. I also asked if there will be any issues with mosfets overheating (I won't be overclocking my gpu). I'll post back here when they respond. Any other solutions, preferably something made to work with the FX 1800 would be much appreciated! Thanks Userremoved.
m
l
June 6, 2010 11:10:18 PM
Great glad I could help!
m
l
June 7, 2010 10:01:53 PM
Best answer selected by futurepower.
m
l
June 7, 2010 10:02:26 PM
Those it work with the FX 1800?
m
l
