Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Advice on first build components
Forum Systems : New Build Advice on first build components
I know you get loads of these threads but I wouldn't mind anyone casting there eyes over this one!
Im trying to keep it as cheap as poss, just a budget PC with casual gaming.
Here goes....
CoolerMaster Elite 330 ATX No PSU Black
Crucial 2GB kit (1GBx2), 240-pin DIMM, DDR3 PC3-10600
Samsung 500GB SpinPoint F3 7200rpm 16MB Sata
Best Value 520W Grey PSU 8cm Fan SATA
Best Value Samsung 22X S-ATA DVD Writer - Black
Microsoft Windows 7 Home Premium OEM 32-bit 1pk
Asus AM3 AMD NF630A DDR3 ATX
AMD CPU Athlon II X3 435 95W AM3 1.5MB 2900MHZ
Asus Radeon HD 4650 PCI-E 2.0 W/LP 1GB
This lot comes to just under £400
Thanks for your help!
Reply to nezbutz
Random gray PSU is not going to be good. Get a good PSU, something like the corsair 400CX isnt too much and you wont risk it blowing up on you.
Reply to hunter315
- 0 +
Cheers, that is one component I was going to change!
Reply to nezbutz
Negative on board: it's just an AM2 with DDR3 slot for RAM (HT limitation, PCIex16 gen 1.0/1.1, etc)
Depending on prices: Rana 440?
Off Ebuyer UK 446 GBP
http://i137.photobucket.com/albums/q205/batuchka/Untitled-1991.jpg
Message edited by batuchka on 07-17-2010 at 09:00:31 AM
Reply to batuchka
- 0 +
Hi
Would this motherboard be a better option...
Asus AM3 AMD 770 DDR3 ATX
As I said I am trying to keep it as cheap as poss!
Reply to nezbutz
That would really depend on how much is selling but that MSI 770 would suffice
Reply to batuchka
- 0 +
The Asus AM3 AMD 770 DDR3 ATX is only £15 quid more, so I can afford that.
Cheers for your help!
Reply to nezbutz
Sure happy shopping/building and you are welcomed ^^
Reply to batuchka
There are 2070 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Need Feedback on $1800 Gaming Build
By Hopz, 1 hour ago:
Could save some money on your PSU and CPU cooler. Unless you want to OC above 4.5 Ghz the...
Best offers
Top experts
