Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > [Solved] Radeon HD 4770 and 28" monitor?
Forum Graphics & Displays : AMD Radeon [Solved] Radeon HD 4770 and 28" monitor?
Best answer from shadow187.
Hi everyone, I have a question.
I have a XFX Radeon HD 4770 video card and I'm planning on upgrading my monitor.
The monitor / TV I'm thinking about getting is this:
Hannspree ST289MUB 28" Class LCD HDTV - 1080p, 1920x1080, 16:10, 800:1 Native, 10000:1 Dynamic, 5ms, 60Hz, 2 HDMI
http://www.hannspree.com/US/produc [...] 92&c=25707
The main online game I play is America's Army, other games include GTA, FarCry etc.
I do photo and video editing.
I also plan to watch HD movies.
With my current video card would you think this monitor would work?
Any pros / cons?
Thanks
It will work, but the HD4770 isn't a great card for 1920x1080. You will have to lower your settings in some games, but otherwise, the card will support the monitor.
Best answer
------------------------------ First Gaming Rig
ASUS DirectCU HD6850(875/1100 @2.12v) ~ Phenom II x3 720(x4-920) @ 3.2ghz ~ 4GB OCZ TITANIUM XTC Series (OC'd to 1066) ~ Coolmax 600W ~ 640GB SATA ~ 4x80mm + 1x120mm
Reply to shadow187
+1^
It will work with that monitor,but i would recommend getting a 5850/5870 for that res
Reply to Maziar
^+2
------------------------------ Core 2 Duo E6300 1.8 GHz (OC at 3.0 GHz) / Zigmatek HDT S1283 CPU Cooler / Gigabyte GA 965P-DS3 Motherboard / 2x1 GB DDR2 800 RAM / 2x160 GB Seagate HDDs / SilverStone ST50F 500W PSU / HIS IceQ 4 HD 4850 512 MB DDR3 / 17" LG Monitor
(Little Dinosaur)
Reply to wa1
^+3
Reply to shadow187
There are 2069 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 1 hour ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
