Will these parts make a good gaming computer?
5 answers Last reply
More about will parts make good gaming computer
  1. Please fill out the sicky so we know more in what you intend to do, just saying gaming computer can mean alot of differnet things.
    -Proc is good
    -Mobo is a 16x, 4x board. If you were every going to crossfire get a 8x/8x minimum.
    -Video card will be good for mid level settings.
    - Better ram for not much more money.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231303&cm_re=g.skill_ripjaws_ddr3_1600-_-20-231-303-_-Product
    - Were you going to crossifre? If so get atleast a 600w psu for two 5770s. If you wanted to OC and add a few more components then bump it up another 50w for safe room.
    - Everything else is fine
    - Have you considered an aftermarket HSF and lube for overclocking?
  2. Is your budget $600? If so, I'd build something more like this:
    CPU/Mobo: X3 440 and HD Gigabyte GA-790XTA-UD4 $183 after rebate
    RAM: GeIL 2x2 GB 1333 mhz CAS Latency 9 $83
    GPU/PSU: HD 5770 and OCZ StealthXStream 600W $215 after rebate
    HDD: Seagate 7200.12 500 GB $55
    Case: Rosewill Wind Knight $35
    Optical: Cheap SATA DVD burner $18
    Total: $589
    The CPU is downgraded a bit, but the board is upgraded to one that will support Crossfire (adding a second GPU), which makes it better overall for gaming. The reason for this is games are mostly dependent on the GPU, not the CPU, so you could easily drop in a second 5770 and nearly double your performance for a cheaper price.
  3. APPROXIMATE PURCHASE DATE: 20-30 Days
    BUDGET RANGE: Under 600
    SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming (everything from hl and css to fallout 3 and crysis)
    PARTS NOT REQUIRED: Case, Mouse, and Keyboard
    PREFERRED WEBSITE(S) FOR PARTS: newegg.com
    PARTS PREFERENCES: prefer ati and amd
    OVERCLOCKING: Maybe
    SLI OR CROSSFIRE: Sometime in the future
    MONITOR RESOLUTION: Haven't picked out monitor yet, looking for the highest resolution
New Build Systems Product
