Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > TV Tuner Cards > LCD Monitor problem Please help :)
Forum Graphics & Displays : TV Tuner Cards LCD Monitor problem Please help :)
Hi everyone :hello:
My lcd monitor comes on for a second then turns black (off) but the green light is still on. so i unplug the power cable then plug it in again and it does the same thing :(
Please any advice whatsoever will be appreciated :sweat:
do you have a second monitor to check your vid output, or a second computer to check this monitor with, even if it's a laptop( providing your monitor has VGA input)
Reply to number13
sirillia wrote :
Hi everyone :hello:
It looks like your monitor goes on power saving mode because there is no video signal coming in.
First, check if the cable is properly connected to the video output port of the PC.
If it is, please tell us whether the monitor display anything before or you have a new PC build.
Reply to randomkid
Hi i have 2 lcd's and only the one works 100%...
The one im having a problem with displays the picture for split second then switches off :(
Reply to sirillia
OK, so it's the monitor, how old is it, warranty? or just get a new one
Reply to number13
Do you mean you connect both your monitor in the same pc through different display port hoping to get dual display? If yes, then you have to set your display properties to "extended desktop".
Message quoted 1 times
Message edited by randomkid on 06-11-2010 at 01:48:06 PM
Reply to randomkid
I only connect 1 at a time now...i know how to use the dual display etc
Reply to sirillia
Not sure of age but its not new
Reply to sirillia
sorry, but we, like the hardware, can only be sure that we'll all die eventually
Reply to number13
yes very true...i just thought it was maybe a minor repairable thing.. i dont think it is too old though lol
Reply to sirillia
the newer LCD's are pretty good, those about 2 years old and older, some mfg's cut corners on cheap intenal controller, and quality is questionable, I am in China, I can take it to a electronics repair place and get stuff fixed that could never have been done in the States
Reply to number13
Sounds like the backlight or inverter are going. If you shine a bright light on the screen after it goes out, do you see a faint image of the screen? If so it's the backlight. do a search for backlight problem for more info.
Reply to fa28
I shone the light on the screen and its just blank...If i put the power switch on the monitor off, then on it does not show the picture quickly as if i had to unplug it and then plug it back in.. :cry:
Reply to sirillia
Take it to your local tv shop and have it fixed by a pro.
Reply to mhelm1
There are 2063 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Bad PCI-E Slot or Bad Graphics Card?
By smorizio, 1 hour ago:
check that you have all the power cables plugged into your video card..some have one some...
Best offers
Top experts
