E edfavor Distinguished Sep 15, 2010 2 0 18,510 Sep 16, 2010 #1 I am having problems finding somewhere to buy a cooling fan for my Gateway DX 4822-01? Do you know where I can order this fan?
Timop Distinguished Feb 27, 2010 3,070 0 21,160 Sep 16, 2010 #2 Did your fan die or something? It uses a standard 80mm, so there are plenty of choices: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007998%20600035580&IsNodeId=1&bop=And&Order=PRICE&PageSize=20 Upvote 0 Downvote
E edfavor Distinguished Sep 15, 2010 2 0 18,510 Sep 16, 2010 #3 It has started making a very loud noise. I have taken it out and checked it and it is the fan to cool the case. It has a funnel on one side between it and the outer case and it has a collar that attachs to a circular fin on the other side. Upvote 0 Downvote
Timop Distinguished Feb 27, 2010 3,070 0 21,160 Sep 17, 2010 #4 Are you talking about the side fan? Mind taking a pic? The fans probably dying due to a bearing, you could try to fix it, but a new fans only $2 bucks anyways. Upvote 0 Downvote
