Help building my gaming PC
Hey i just had a quick question. I just bought my PSU and i was wondering if I could hook it up and test out the fans etc.. but I only have a mobo, ram, hdd, and cd rom installed no CPU. Can i still hook up my power supply? i just wanted to check before i did so i didnt hurt anything
Thanks,
Cody
3 answers Last reply
More about help building gaming
  1. You can do the paperclip method to jump start your PSU.
    1) Get a Paperclip
    2) Connect one end into the Green Wire Slot on the 20/24-pin ATX connector
    3) Connect the other end into a Black Wire Slot on 20/24-pin ATX connector
    4) PSU is now jumped...
    1) Get a Paperclip
    Alright Cool thanks! So ill try that but than can i hook it up cause i have my mobo hooked up and i was gonna hook it up to my monitor i have no clue what wil hapen without a cpu though?
  3. It won't boot without a CPU installed, so you won't really see anything.
New Build Gaming Systems
