Solved
Samsung monitors help
Hey there everyone!
I'm on a roll to buy any one of these monitors, but i'm having trouble decide...
Samsung XL2370-1
I also thought of hooking a tv tuner until I uncovered these models
Samsung XL2370HD
Samsung P2570HD
I'd like to stick with this manufacturer. The card in my info will be replaced by an Asus Matrix 5870 Platinum(hopefully) but which one would be a better buy and if the tv tuner is any good :heink: ?
Thanks!
6 answers Last reply Best Answer
More about samsung monitors help
  1. What do you want your monitor to do? The XL2370-1 is a standard Hi def PC monitor, while the other two have TV tuners so you can use it as a television too. If you don't need the ability to watch television on it I'd go with the XL2370-1, personally.
    well i'd want to watch some TV in my studio workspace...thus the find. I use CAD/Google Sketchup/Photoshop CS4(and the Adobe Master suite CS4) heavily, i play almost all titles in games and am a movie/Bleach fanatic
    so there you have it :)
  3. Best answer
    In that case I would personally choose the P2570HD, it has everything you seem to need.
  4. Best answer selected by Lutfij.
    Why specifically the P2570HD when the XL2370HD is newer technology and LED backlit? I understand it's a tad smaller, but I just want to know a reason for this recommendation.
  6. Size perhaps...i liked its connectivity as well...and you can wall mount it
Homebuilt Tuner Monitors Samsung Systems
