Clarification needed on TriCool and power connection
Hello,
This is my first computer build and I understand everything except I'm confused on the fans.
I have four Antec TriCool's. One on the top, back, and two front.
I'm not comprehending if I'm supposed to connect all of them to the PSU or as some suggest to the motherboard.
I have an Asus P7P55D motherboard, so besides the CPU_FAN, I see:
CHA_FAN1
CHA_FAN2
PWR_FAN - I guess this can also be used?
So that's only three.
And besides seeing the RPM on the BIOS screen if I understood correctly, will there be any other benefit to install it to the motherboard?
These particular fans have a wire that controls the speed, I don't think the motherboard will be able to select the low/med/high switch.
I'd greatly appreciate any advice on this. Thank you.
5 answers Last reply
More about clarification needed tricool power connection
  1. I have a 902 and 5 tricools all hooked-up with 4pin molex to my psu.
    PWR_FAN is usually a psu connection.
    And CHA_FAN headers are for additional chassis/case fans.
    There's no need to connect them to your mobo fan headers and the 3speed controls are on the exterior of your case.
    Leave the exhaust fans at the factory setting which is low.
    The front intakes can be adjusted to whatever you like i generally leave all 5 on low and occasionally i'll adjust my intakes higher when gaming heavily.
  2. Thanks for the response and tips.
    You mentioned that the 3 speed controls are on the case exterior, I guess you mean on your case? Mine doesn't seem to have that feature, it only has a power on and reset button. The case is an Antec Three Hundred.
    I did a lot of googling about this matter and seems a lot of people are giving conflicting info and I'm still confused.
    IF I can control the 2 additional fans - I was planning to put as intake - via my motherboard, I would definitely be interested rather than having to open up the case to adjust settings. My motherboard manual says it has chasis q-fan control.
    Some people are claiming it's not possible with Tricools while others say you can set it to High, connect to the motherboard, and you can adjust easily.
    I guess I will have to try it and find out, I just don't want to fry anything. :)
  3. Where you get the TwoCool and TriCool fans determines on how you can control them. The fans that come with our cases can only be connected via molex. Out of the box, you wouldn't be able to control these aside from the hardware switches because they'd be plugged into the power supply, not the motherboard.
    If you purchased one of our fans from a store, they do come with a 3-pin adapter that would allow you to plug the fan into the motherboard, allowing you further control.
  4. We appear to have another antec rep now, cool!
    Like Jessie said, tri cools have little black 3 way switches on a 3 inch ish cable that comes off the fan, so that when you plug them into the PSU you can adjust their speed, unless you mod the case you will need to open it up to adjust their speed but i find it unlikely that you will be adjusting their speed that often. Like Davcon said low is pretty good and quite quite on the Tricools so if you have 4 of them i would leave them set to that, it should keep everything nice and cool.
  5. +1 for low speed, Medium and high are too noisy.
Antec Connection Motherboards Components
