Dirty Power flows through the lines in my country. Spikes, surges and sags are quite common and so are power failures.
I believe that dirty power was the reason why my Seagate HDD failed in the first place.
So, after having done my homework I arrived at the conclusion that I need to buy a UPS thatw ill give me some line and load regulation and protect my HDD and laptop.
In case of power failures, the backup inverter kicks in which basically converts DC stored in a battery to AC. The problem is that it supplies 300V at 50Hz while the normal voltage required is 220V at 50Hz.
Will the line regulation provided by UPS be of any use here? The backup invertor kicks in real quick and starts supplying the 300V.
What do I do? Buy a UPS for line and load regulation and spike/surge/sag protection or not?
PS: The sags take the voltage down to 180V or so and surge goes to 230V. Fluctuations are present like oxygen even as i type.
