480W Power Supply enough for Nvidia GeForce GTS 450?
  • Power Supplies
  • Geforce
  • Nvidia
  • Components
  • Product
Last response: in Components
Anonymous
a b ) Power supply
September 17, 2010 12:40:03 AM
Hello,
I have been wanting to upgrade to an Nvidia GeForce GTS 450. I'm getting bored of running Battlefield Bad Company 2 on low settings with my XFX ATi Radeon HD 4670. I wanted to know if my PSU is good enough for it. According to tigerdirect.com, it says that the minimum PSU requirement is 400W. I just want to make sure that I'm not cutting it too close or anything. Here are my computer specs:
Windows 7 Home Premium (64-Bit)
AMD Athlon II X4 620 @ 2.6GHz (not overclocked)
4GB DDR2 memory (2 sticks @ 2GB per stick)
XFX ATi Radeon HD 4670 (not overclocked)
480W Black Steel PSU
If this helps, these are the numbers on the 2 rows of my PSU:
Row 1: |+3.3V| |+5V| |+12V| |-12V| |+5Vsb| |Total|
Row 2: |28A| |34A| |18A| |0.8A| |2A| |480W|
This is the card I want to buy: http://www.tigerdirect.com/applications/searchtools/ite...
I was hoping to buy the card this weekend, so any help would be great ASAP!
Thanks -- gotsupra1337
More about : 480w power supply nvidia geforce gts 450
a c 722 ) Power supply
a c 165 Î Nvidia
September 17, 2010 12:52:13 AM
It needs 22 amps on the +12volt rail you have 18
m
l
a b ) Power supply
a b Î Nvidia
September 17, 2010 1:01:31 AM
The GTS450 uses 20W more than the HD5770, no a bigger no.
m
l
Anonymous
a b ) Power supply
September 17, 2010 1:14:48 AM
Alright guys, thanks for the reply's! I probably buy a new PSU then.
m
l
a b ) Power supply
September 17, 2010 1:22:29 AM
get a high quality unit from corsair, nzxt, seasonic, antec, etc. do not buy a cheap psu, like huntkey, raidmax, okia, coolmax, powmax, basically you get the point :)
m
l
a b ) Power supply
September 17, 2010 1:33:10 AM
Better get a HD5770 or even better wait for a few weeks for the new ATI 6 series to hit the stores. The 450 is a new arrival, the price is not set yet and definitely it will be cheaper soon. The 5770 is getting cheaper by the day.
If you want to upgrade now here's a sweet deal:
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
Price After Mail-In Rebate(s): $144.98
m
l
a b ) Power supply
a b Î Nvidia
September 17, 2010 3:39:57 AM
yeah, really, get a 5770 - faster/cheaper....unless you plan to SLI down the track.
m
l
August 28, 2012 8:46:34 PM
...although that particular model maybe not a good example of Corsair's quality which I still trust more than a bargain brand.
m
l
