Hi,
I have recently purchased the following rig:
I7 920 @ 4.0 Ghz
Corsair H50 cooler
6GB 1600Mhz RAM
1TB Segate HDD
HD5770 Vapour-X
Antec 300 case
When I first turned the system on it was too loud. I have since turned down both the fan at the top of the case and the fan attached to the H50 to their lowest settings. It's now almost inaudible.
I am worried that the system could overheat? I have monitored the CPU with RealTemp and this is fine even under load (hovers around 40 idle, reaches mid 70's at max).
However is there a chance that other components could overheat or an I worrying about nothing?
Thanks in advance.
I7 920 @ 4.0 Ghz
Corsair H50 cooler
6GB 1600Mhz RAM
1TB Segate HDD
HD5770 Vapour-X
Antec 300 case
Thanks in advance.
