I'm very out of the loop on the performance parts available now and could use some help regarding building a PC to support my Final Fantasy addiction. Would like to keep it under 1k so that the wife doesn't completely kill me when I tell her I'm buying a PC to play a game. Been using a Mac for the past 5 years or so, thus the reason I'm a bit lost on many of the components and what is best to choose:
Initial thoughts (really no tilt either way, read reviews and many go either way):
AMD Phenom II X4 965 (http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=phenom+ii+x4+965&x=0&y=0)
or
Intel i5 750 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215&cm_re=i5_750-_-19-115-215-_-Product)
Not really sure at all on MB though it looks like the Asus is the way most people are going with the Intel chip
Likely go with 6GB RAM - sounds like the G.Skill is the best thing out there now.
Not sure on NVidia vs ATI for the GPU and no specific preference either way
Plain old case/DVD/PSU, etc, don't need anything fancy. Also as a Mac user I'll have to buy the OS.
Already have a 19" monitor. I'm sure I'll upgrade at some point but it's a decent display for the time being.
Any help would be greatly appreciated.
Thanks!!!
or
Thanks!!!
