Well, if a particular program allows you to set a non-default sound output, you CAN stream two audio streams at once. Aside from that, the options to allow for multiple sound outputs are very limited in Windows...
What are you trying to accomplish? Might be easier to use some form of a switch if you're trying to get output to two external devices...
