Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Battery in or out when on A/C?
Forum Laptops & Notebooks : General Laptops & Notebooks - Battery in or out when on A/C?
Archived from groups: comp.sys.laptops (More info?)
I have been reading some back posts here that (strongly) recommend to
remove the batteries from the laptop when it is on A/C. I can't find
the owner's manual for my Omnibook 6000 (3 years old) right now, bit I
am pretty sure that it does not make this recommendation.
Is there solid data to support this recommendation? Because it is a
big pain to have to take the battery in and out every time I plug it
in.
If this is such a big problem, why don't the laptop manufacturers
include circuitry to eliminate the problem?
Thanks
PC: HP Omnibook 6000
OS: Win 2K SP-4 (5.00.2195)
LAN: P2P with an HP Vectra workstation
Email: Usenet-20031220 at spamex.com
(11/03/04)
Sponsored Links
> in.
Let the battery inside.
The information is based on technology 10 years ago.
Now there are Lithium Ion instead of NiMh,
now there are far better chargers built in
It's an ancient legend.
It's like You shoud bring the battery of Your car and the
sparks inside Your house in order to start Your car
in winter.
Was really necessary 1930 or so.
Roland Mösl
http://www.pege.org Clear targets for a confused civilization
http://web-design-suite.com Web Design starts at the search engine
Reply to Anonymous
"Roland Mösl" <founder@pege.org> wrote in message
news:4191c406$0$25104$91cee783@newsreader02.highway.telekom.at...
> > in.
> in winter.
Not bad advice if you don't mind spending $120 or so replacing your battery.
Remove it when not needed for long periods(such as using it as a desktop for
months at a time). Li on batteries are far better than their older
counterparts but they do go bad and are much more expensive to replace.
Reply to Anonymous
On Wed, 10 Nov 2004 06:16:27 -0500, ";-p"
>> > in.
>> in winter.
My laptop runs on A/C 99% of the time. It sits on my home office desk
plugged into A/C with the battery in all day and all night, 24/7,
except for (a) almost daily trips to my client office for a few hours
and 4-5 times year on trips. On those trips, it runs on batteries
whenever I can't find an A/C plug.
I like to run with the battery in for the power outage protection. I
also like having the battery fully charged all the time.
I have had this laptop for over 3 years running it this way all that
time. Just this last few months the battery has started to lose
capacity.
However, it travels betweeen my home office and clent office almost
every day -- meaning that it gets powered off and on each time that
happens.
(11/09/04)
Reply to Anonymous
>> > in.
>> in winter.
> battery. Remove it when not needed for long periods(such as using it as a
> desktop for months at a time). Li on batteries are far better than their
> older counterparts but they do go bad and are much more expensive to
> replace.
If you do that you need to recharge the battery periodically to keep it from
flatlining. Once the charge level on a lithium ion battery goes below a
certain level its protective circuits kick in (after a few spectacular
explosions the manufacturers started adding protective circuits to lithium
rechargeable batteries of all flavors) and it can no longer be charged.
--John
Reply to jclarke at ae tee tee global dot net
(was jclarke at eye bee em dot net)
Reply to Anonymous
On Wed, 10 Nov 2004 09:34:19 -0500, "J. Clarke"
>>> > in.
>>> in winter.
>> replace.
Hmmm... That may be what happened to my battery. I went on a long trip
on an airlone without laptop outlets. I used the laptop down to the
very last 2-3 minutes of battery power before shutting the machine
off. It then sat for a day or so in my briefcase fully discharged.
(11/09/04)
Reply to Anonymous
> capacity.
The same happens both ways.
Lithium Ion degrade by time, regardless of use.
You can maybe reduce the degradation by some %.
So for making Yourself a battery in and out monkey,
Your battery could be in 40 month as bad as
after 36 month with normal tratement.
Let's split 120 on 36 or 40 month, and the difference
is 33 Cent per month.
Some peopel like to be a monkey for just 33 cent a month.
I am no monkey, a power outage would cost me without
battery shure more than $100.
Roland Mösl - http://www.pege.org - http://notebook.pege.org
http://wds-internetwerbung.com Web Design startet an der Suchmaschine
Reply to Anonymous
There is lots of information available via your favourite search engine in
regard to use and storage like
http://www.batteryuniversity.com/print-parttwo-34.htm but in brief the
battery manufacturers appear to recommend any battery kept in storage for
long periods is left at around 34% if memory serves.Whilst Li-On batteries
do not suffer from a charging memory like older types their life span is
usually given as between 3-5 years before a replacement should be sought on
critical equipment.
Reply to andi
> Fourth, while there is an argument to be made for keeping the battery in
> the laptop as a UPS, it's a very expensive solution. In fact, it's a
> $200 solution to a $30 problems. Almost all of the lithium based
> batteries cost over $200. You can buy a 350va UPS (and I'm talking APC,
> not junk) on sale for $30 or less. $30 or $200, which do you want to
spend?
$200 shure.
The cheap UPS does not work when I change from one
room to an other room.
Roland Mösl
Reply to Anonymous
Re:
> spend?
> $200 shure.
We were talking about a "fixed" laptop sitting on a desk -- basically a
desktop replacment (even if only for a few days). The minute the laptop
moves, whether it's to the next room or across the country, you have
changed the ground rules of the situation under discussion.
Reply to Anonymous
> only in Thinkpads, to buy a R51. And I think IBM has the answer to this
> problem: the machine does not charge the battery if - in my case, the
> settings are adjustable - the charge level is between 95 and 99% full.
All Li-Ion chargers are *supposed* to do this. Li-Ion batteries are
rated for a certain number of charge-discharge cycles. Unfortunately,
a "cycle" is eaten whether you discharged the battery to 1% or to
99.999999%. So smart chargers do exactly what you describe here.
Problem is, it's very hard to tell what exactly is happening in a
laptop unless the manufacturer tells you details (which most don't).
The "charge" indicator does not really mean what the manual says it
does. The first phase of the "charge" process is to interrogate the
battery's micro and start a cell test, during which time no actual
charging is going on. The cell test can take several seconds.
So simply seeing the charge LED go on briefly when you plug in a full
battery doesn't really mean it was charging.
Reply to Anonymous
On Fri, 12 Nov 2004 05:05:35 GMT, Barry Watzman
<WatzmanNOSPAM@neo.rr.com> wrote:
>Re:
>> spend?
>> $200 shure.
*You* were talking about a fixed laptop sitting on a desk.
This is a valid scenario, but hardly the only scenario and probably
not even one of the most common scenarios. My laptop sits on a desk
99% of the time plugged into A/C. But it might be my home office desk
or my client office desk. Occasionally, I need to take it into another
room for a short period of time. When I do, I just unplug it and go.
Also, when I am powering it of to go from one office to the other, I
often start disconnecting the cabled (power, printer, cat-5) while it
is powering down. With the battery removed, I would have to be careful
to wait until it was all the way off before disconnecting the A/C.
Finally, I sometimes take it to the car still running because it has a
map or other information on it that I want to look at on the way or
where I am going and I don't want to wait for W2K to come back up.
The point is that my time is worth something. The aggravation of
having to remember one more detail about the laptop, which is supposed
to be a tool for my convenience, defeats the purpose.
(11/09/04)
Reply to Anonymous
According to Watzman
Do You like to be free?
If Your answer is no, just go in the next bank with a pistol.
You will recieve 15 years free residence in a house named prison.
When You compare this against the usual $1000 a month rent
of an appartment, You can save with this action
$180.000 rent for an appartment.
The only small disadvantage: You are not free
Roland Mösl
Reply to Anonymous
news:4195feab$0$25176$91cee783@newsreader01.highway.telekom.at...
laptop
You are arguing apples and oranges. Run free if you wish, Great! The
discussion is regarding using the laptop as a desktop on a continuing basis.
There are instances where you need to git and go but if used solely as a
desktop then I still say "Remove the battery" untill needed.
Reply to Anonymous
I'm not convinced this topic has received the substance it deserves --
but there is something there after all.
Namely, seems to me it makes *lots* of sense to run your laptop from a
UPS, no battery, if it's going to be in one place for a while. Those
battery prices, I believe, can only be ripoff rates.
However, Topspin's comment about disconnecting his laptop while it was
shutting down, seems to me another topic. This topic is *haste*. And
in my view, his laptop's good health and the usual good access to what
it holds today, are all *very much* more important than the seconds
saved by haste. Further, I recently saw news of a study of
multi-tasking, another hasty time saver, which showed that when
someone multi-tasks, all the tasks get done less well and slower than
when done one at a time. Which also, I suspect may be relevant to
Topspin.
Cheers -- Martha Adams
Reply to Anonymous
Now how is it that the UPS battery will hold up in this service but the
laptop battery won't? Seems to me you're trading one battery replacement
for another. And it all strikes me as cheap for the sake of cheap.
> Topspin.
--John
Reply to Anonymous
"J. Clarke" <jclarke@nospam.invalid> wrote in message
news:co7nf332r8j@news3.newsguy.com...
A UPS battery lasts for several years and is likely less expensive than a
notebook battery.
However, won;t running without the notebook battery cause the notebook
battery to discharge?
If left out long enough, you might not even be able to recharge the notebook
battery.
Reply to Anonymous
"Howard Kaikow" <kaikow@standards.com> wrote in message news:<co7qcg$j2k$1@pyrite.mv.net>...
> notebook battery.
> battery.
The point is---take care of your battery. There is a need to discharge
and recharge from time to time. Earlier posts suggest that a new
laptop battery may cost little when broken down by monthly cost and
that is true BUT try to find a new laptop battery for a 5 year old
machine. Good luck finding one that won't require a home equity loan.
Reply to Anonymous
>> > replacement
>> notebook battery.
>> notebook battery.
(a) I had no trouble finding one for my 5 year old laptop and
(b) what are you running on that 5 year old machine anyway?
--John
Reply to Anonymous
Re:
First, the UPS battery is lead-acid, the laptop battery is lithium ion.
They have completely and totally different chemistries and
characteristics. The lead-acid battery will last for several years in
this type of service.
Second, the UPS battery costs about $12, while the Laptop battery costs
over $200. So if you were "trading one battery replacement for
another", that's still perfectly fine. Note, however, while the
capacities of the two batteries are the same, the lead-acid battery
weighs about 10x more than than the Lithium battery. In fact, when
replacing the lead-acid battery, the shipping cost can be more than the
cost of the battery itself.
All batteries are no more similar than are all cars; a Yugo and a Lexus
are not comparable.
Reply to Anonymous
Re:
> battery.
Not really a concern. The battery can be put back into the notebook and
"topped off" every 90 to 120 days (which will probably happen by itself
if the notebook ever does any actual travling involving portable
operation). Some sites recommend that Lithium batteries are best stored
at 40% to 60% charge, others say full charge, with "top off" at about 90
to 120 days.
However, there was a thousands-of-posts long thread on this subject
[here] about 18 months ago, and the overwhelming consensus of actual
users was that leaving the battery in the laptop will essentially
destroy it in 6 to 18 months, while many Lithium batteries that do not
experience such use will last the better part of a decade (I have not
one but several Toshiba "2487" lithium batteries made in 1997 that are
still in good enough condition to run a laptop for 2 hours).
Reply to Anonymous
"J. Clarke" <jclarke@nospam.invalid> wrote in message news:<coah3j01lt2@news2.newsguy.com>...
> >> > replacement
> >> notebook battery.
> >> notebook battery.
I find no problem using a 5 yr old laptop actually it's 6. A Fujitsu P
II 233. Has Win98 and everything I use and still does it well. Not
everyone needs or wants the latest or greatest. I did find a
replacement battery finially at a decent price. I now take much better
care of the battery and remove it when used as a desktop.
Reply to Anonymous
Pardon if I jump in here, I just joined this ng.
With regards to your battery question I'd like to point out that it's
not only a battery issue. Some laptops, especially older designs, use
the battery as sort of a regulator! It stabilizes the voltage coming
in from the external source connector.
If a battery is out of the laptop, the voltage could possibly exceed
some design criteria.
Bottom line - it depends on how the laptop was designed.
Just my past experience ...
-=tom=-
Reply to Anonymous
There are 1116 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
