Hello everyone. First of all, thank you for taking a glance at my thread & hopefully able to help me out a bit. (i luv this site)
I have a Dell Studio 540 desktop & I recently upgraded my graphics card to an ATI Radeon 5770, everything else is factory. Now, after I've been gaming for a few hours, the fans really start to wind up, & the air coming out the back gets pretty warm. Sometimes the game even slows or gets jerky. When I crack open the case, air inside doesn't necessarily feel hot, not even around the graphics card. I really need to get this overheating issue under control ASAP because FINAL FANTASY XIV comes out Wednesday, so I'm sure I'll be spending alot of time on the game.
I do know one thing, my power supply is being pushed pretty hard. Rated max 350w & PSU calculators recommend 325w for my system (280w min). A guy with GeekSquad told me a bigger power supply should solve the problem because they have bigger fans that take out the hot air.. Also, I know Dells aren't built for good airflow.
So, I was thinking of upgrading my PSU to maybe a 750w? Since I'm going to upgrade rest components/case in a couple years when I got $$ instead of buying a new PC. Now, I got about $100 to deal with this heat problem. So, do you guys think I'm on the right track? Do you have any other recommendations to rid the heat ?? And most importantly, I've heard Dells have trouble fitting in larger PSUs. Has anyone put a bigger power supply in a Studio 540 before ???
My factory PSU Model: ATX0350D5WA Rev.:A00 measures at 6"wide x 3.5"tall x 5.5" long
I think this is it > http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php
These R the PSUs i'm looking at -- http://www.corsair.com/products/tx/default.aspx
1) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3438609&CatId=2533
2) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4668506&CatId=2533
3) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3438607&CatId=1483
Thank you so much, again. Peace
