Will gtx470 sli fit inside Antec DF-30 case?
Will a gtx470 sli fit inside the Antec Dark Fleet 30 case?
Thanks for answers and help!
2 answers Last reply
More about will gtx470 inside antec case
  1. easily, Ive looked at the case in store before. It has a good amount of room for two cards plus the specs below
    the GTX 470 is 9.5" in length
    http://www.nvidia.com/object/product_geforce_gtx_470_us.html
    the case will fit cards up to 11.5" / 292 mm
    http://benchmarkreviews.com/index.php?option=com_content&task=view&id=575&Itemid=61
  2. ^+ he's absolutely correct about that.
Power Supplies Antec Cases SLI Components
